1. eldemya's Avatar
    I received an OS upgrade today on my Galaxy S7. Once again the display has been reduced to minimal colors on items like Phone, Calendar, Contacts, Settings Display and others. I cannot remember what to change in the settings to get full color display back again.
    03-30-2017 03:50 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you mean it's in greyscale? Look for a greyscale option in the Display, Battery, or Accessibility menu. Also make sure you're not in ultra power-saving mode.
    03-30-2017 04:19 PM
  3. eldemya's Avatar
    Greyscale is Off (under Vision)
    Battery Power Saving Mode is Off
    Performance Mode is set to Optimized
    I have Developer Mode available but I don't see anything in there that looks like it would address this. I know it has to do with a setting that is restricting the colors from being displayed... but which one?
    03-30-2017 06:26 PM
  4. eldemya's Avatar
    Anyone have any ideas???
    03-30-2017 08:34 PM
  5. B. Diddy's Avatar
    Could it be some 3rd party app? Does it remain in greyscale if you boot into Safe Mode? https://support.t-mobile.com/docs/DOC-28008
    03-31-2017 01:24 AM
  6. eldemya's Avatar
    It is only effecting the Samsung/Android apps like Phone, Calendar, The Apps menu at the top of the screen, Notifications and the Keyboard. Also my battery has been discharging a lot more than normal since the update.
    03-31-2017 01:57 PM
  7. eldemya's Avatar
    Oh and Safe Mode didn't make a difference.
    03-31-2017 01:59 PM
  8. B. Diddy's Avatar
    Have you already tried wiping the cache? https://support.t-mobile.com/docs/DOC-24999
    03-31-2017 03:42 PM
  9. Daniel Bader's Avatar
    When you say once again, this has happened before?
    Is it possible that this is just how the new apps look? The GS7 update to Nougat made the colors lighter and simpler.
    04-11-2017 07:55 AM
  10. eldemya's Avatar
    Hi Daniel,
    Thanks for following up with me.
    After the previous OS update my phone lost the colors on all of the basic Samsung or Android app. I was eventually told to check a setting that may have been defaulted to a selection causing this and it cleared up the issue for me. I cannot remember what the setting was.
    Now after this latest OS update I have the same issue.
    I have attached two pictures. One is what my phone screen looks like when I am making a call. Notice the lack of the solid bright Green and White screen. The second is my Contacts screen. Notice the total lack of color. Also look at the very top where the icons are and see how shallow they are.
    I have checked every performance and power setting looking for the setting that would put the basic screens into this mode but I have not been able to find it.
    Any help or guesses are very much appreciated.
    Thanks,
    Mark
    OS Upgrade S7 Display Issues-screenshot_20170411_221703.jpgOS Upgrade S7 Display Issues-screenshot_20170411_221508.jpg
    04-11-2017 09:27 PM
  11. eldemya's Avatar
    04-16-2017 08:27 AM
  12. 11B1P's Avatar
    My guess is that it's due to your theme or launcher. When I make a call, my screen has the same looking color scheme (not that it bothers me, the phone is either next to my ear or on speaker, so I don't notice it).
    My contacts screen colors match my theme.
    04-16-2017 09:27 AM
  13. eldemya's Avatar
    I thought that too and tried changing the Theme to a different one but that didn't resolve the issue. Thanks for your feedback.
    11B1P likes this.
    04-19-2017 08:52 AM
  1. Samsung Galaxy S7 Edge "Failed to obtain IP address
    By Ms_Sarah in forum Samsung Galaxy S7 edge
    Last Post: 03-03-2019, 02:39 PM
  2. Samsung S7 edge software update sucks!
    Last Post: 03-30-2017, 06:21 PM
  3. responding issues to text
    By AC Question in forum Samsung Gear S2
    Last Post: 03-30-2017, 04:40 PM
  4. Why is the battery like on S8plus less then my S7 edge?
    Last Post: 03-30-2017, 03:12 PM
