1. Paula45's Avatar
    I have had my tab A for a couple years now. It has never given me a problem until the other day. I was watching Netflix when it crashed and said network error try again later. So it tried later and same message. Then I deleted the app to try to reinstall it. The play store would not load. For 2 days I have been playing around with it. None of the apps would load. So I reset it, turned flight mode on and off, restarted it. Nothing was working. So I formatted it using the home + power+ vol up button because I could not format it from the settings. Now after I connect the tablet to the internet it doesn't connect to the playstore so it does nothing but says not connected to network. The wifi is clearly working as I have numerous other devices connected to it. Does anyone know how to help?
    04-03-2017 01:23 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you only tried this on your home wi-fi network? What about other networks?
    If you only have access to your own wi-fi network, try rebooting the router by unplugging its power for 10 seconds. See this guide for more ideas: http://forums.androidcentral.com/amb...-problems.html
    04-03-2017 01:40 PM
  1. Unable to connect to any University WiFi
    Last Post: 04-03-2017, 06:31 PM
  2. Replies: 1
    Last Post: 04-03-2017, 01:50 PM
  3. Replies: 1
    Last Post: 04-03-2017, 01:49 PM
  4. Lg to samsung calendar sync
    Last Post: 04-03-2017, 01:44 PM
  5. Replies: 1
    Last Post: 04-03-2017, 01:41 PM
