1. CorruptedW's Avatar
    This morning i turned on my phone coming up with an error about the "LEAGOO launcher" and if i wanted it to update it or not since it would "Track my position" i tapped on "ok" out of the options "later" or "ok". This lead to the "launcher.something..." to crash. then i had a black screen with just the top bar. I tried to restart my phone but it is just stuck at the loading screen and never changes. This happened to my sister a few days ago and we are both very confused. Any help?
    04-08-2017 08:25 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Recovery and wiping the cache partition: LEAGOO Lead 6 - Recovery Mode - HardReset.info
    04-08-2017 04:48 PM
  3. nadsboogie's Avatar
    I have the same problem did you have any luck?
    04-10-2017 05:52 PM
  4. Oldfart66's Avatar
    I have the same problem.with leagoo 6 just frooze ..its week old I cannot get into boot mode.help
    04-14-2017 09:13 AM
  5. Oldfart66's Avatar
    Did you sort yours.mine has frooze on start up
    04-14-2017 09:14 AM
  6. CorruptedW's Avatar
    Sorry for the very late reply but no...
    Like i said in my explanation it doesn't even get to the point i can reset it since it doesn't even turn on.
    It just stays on the loading screen with "leagoo" in the middle and "For the best experience" at the bottom.
    04-22-2017 07:10 AM
  7. B. Diddy's Avatar
    I'm afraid it's either a corrupt firmware or faulty hardware. Is the phone still under warranty?
    04-22-2017 10:10 PM
  8. CorruptedW's Avatar
    Nope, guess ill just have to get a new phone.
    Thank you for everything though
    B. Diddy likes this.
    04-28-2017 02:03 PM
  9. B. Diddy's Avatar
    Sorry about that. When you get a chance, head over to the Introductions forum and tell us something about yourself! Introductions
    05-01-2017 01:31 PM
  1. why does my zte not accept a simple flashlight app that I've downloaded?
    By swalsh787 in forum General Help and How To
    Last Post: 07-14-2018, 04:18 AM
  2. Why do my Bluetooth headphones only work for calls?
    Last Post: 04-08-2017, 05:11 PM
  3. unlock phone whose screen which is damaged
    By rameshjey in forum Samsung Galaxy S4
    Last Post: 04-08-2017, 04:52 PM
  4. Why is my battery draining so fast?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-08-2017, 08:07 AM
  5. Why is my battery draining so fast?
