1. pollie00's Avatar
    Hey, so I currently have to devices, a Nexus 6p and a LG G5. The G5 I received on the last Best Buy promo for $5 dollars a month. I think the 6p is probably the best Android I have ever had. The two reasons I got the G5 was potential trade in value for a flagship this year and the worry that the Nexus wouldn't get updates past this fall. Well the trade in idea is kind of out right now because Verizon wants you to go to unlimited to get any value. The G5 is ok, my plan was to sell my 6p. For right now the best quality of the G5 is the camera and the size (6p is pretty big). But the 6p is just seems better in ever other regards. Any suggestions on what I should do?
    04-16-2017 09:30 PM
  2. robk84's Avatar
    Keep your 6p, it will get the big update this fall and next year you can upgrade to a pixel 2 when prices are discount.
    04-18-2017 04:09 PM
  3. LuxuryTouringZone's Avatar
    If speedy updates are your priority, then I can understand why it would make sense to keep the Nexus 6P. I'd personally route for the LG G5 since it too will receive Nougat, albeit later, has a phenomenal camera, removable battery, microSD card slot, great display and modules. Oh, and it's easier to repair if you ever wanted to attempt that!
    04-23-2017 01:40 PM
  4. MrMobile's Avatar
    If it were me, I'd stick with the 6P as well.
    04-24-2017 09:02 AM
  5. SugaryxTibs's Avatar
    Nexus 6P for sure.
    05-04-2017 01:59 AM
  1. Unable to replace the sorted images by name to my device
    Last Post: 04-17-2017, 06:52 PM
  2. Replies: 1
    Last Post: 04-16-2017, 09:14 PM
  3. Replies: 1
    Last Post: 04-15-2017, 06:18 PM
  4. Files found on my device storage
    Last Post: 04-14-2017, 05:06 PM
  5. Replies: 3
    Last Post: 04-14-2017, 02:18 PM
