Watch UFC 245 Exclusively on ESPN+
Catch Every Moment of UFC 245 Experience UFC PPV events like never before with ESPN+ and save over 25%!
Expand Minimize
  1. Mariah Lynn's Avatar
    I just bought a new Google Pixel XL. Today I went on Android Pay to try adding my Visa debit card and after putting in all the info and clicking submit, it took me back to the main "get started" screen. Also tried my Capital One card (MasterCard) and it did the same thing.
    I did try clearing the data and force closing the app. This was my first time trying to use it. If anyone has any advice I'd appreciate it, thank you
    Attached Thumbnails First time using Android Pay, will not add card?-screenshot_20170417-201300.jpg
    04-17-2017 08:11 PM
  2. H3aTeRzz's Avatar
    I would contact support....if you're not willing to do a factory reset. Might see if the uninstall option is available, if it is, uninstall and reinstall android pay. I can't remember if thats possible or not. Good Luck!
    04-17-2017 10:16 PM
  3. Mariah Lynn's Avatar
    Tried reinstalling and it worked! Thank you.
    04-18-2017 10:20 AM
  1. Replies: 1
    Last Post: 09-26-2017, 05:13 PM
  2. Replies: 91
    Last Post: 07-26-2017, 02:03 PM
  3. My phone is not charging at all?
    Last Post: 04-17-2017, 10:27 PM
  4. Replies: 1
    Last Post: 04-17-2017, 10:19 PM
  5. time zone problem Azerbaijan
    Last Post: 04-17-2017, 06:20 PM
