Hi
Could be a bad battery. This could be because it was at the end of its life, or it suffered damage from a drop or liquid. I would suggest trying another battery, to see if it could be that....BUT...if you dropped it or liquid entered it, I would take it to a certified repair place, because it could be a fire hazard!
Hope this helps, Good Luck!
Chris
