1. Foxmcloud1990's Avatar
    Is there any way to set my phone to trust my car and keep it unlocked, but not have it actually connected to Blu tooth? Even if I turn it to media only, for some reason every time I hit a button, like going into settings, it stops the radio for a couple of seconds then resumes.
    04-24-2017 09:05 AM
  2. B. Diddy's Avatar
    When you say "turn it to media only," do you mean you're going to Settings>Bluetooth, tapping the gear icon next to the car system, and unchecking Media Audio?
    04-24-2017 10:29 AM
  3. Foxmcloud1990's Avatar
    Yep
    04-24-2017 10:58 AM
  4. B. Diddy's Avatar
    Which phone do you have? Trusted Devices requires a Bluetooth connection, so you're stuck with that requirement.
    Is Media Audio checking itself back on, or does it stay unchecked?
    04-24-2017 11:01 AM
  1. bluetooth is only connecting to phone but not for media
    Last Post: 04-24-2017, 09:51 AM
  2. Best Performance Mode?
    By Extremevl in forum Samsung Galaxy S8 & S8+
    Last Post: 04-23-2017, 06:36 PM
  3. S7 edge camera pro mode broken after nougat update
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 04-23-2017, 03:38 PM
  4. S7 edge camera pro mode broken after nougat update
    Last Post: 04-23-2017, 02:34 PM
  5. Nougat and Bluetooth Music
    By MK Redding in forum Samsung Galaxy Note 5
    Last Post: 04-23-2017, 02:02 PM
