1. captnpenguin's Avatar
    I have an s6 that just got the Nougat update finally and I am still enjoying the Google Now launcher. One of the things I love about it is the swipe left from home screen to access the now cards. I am considering switching things up launcher wise, but I was wondering if there are any other launchers that allow the swipe left to access Google Now or if I have to stick with Now Launcher or get a Pixel (not an option). Thanks!
    04-26-2017 09:25 AM
  2. Javier P's Avatar
    That's a tricky one. The swipe left action for Google Now is not available in most launchers. This is Nova launcher creator explaining why.
    https://plus.google.com/+KevinBarry/posts/9nQzgKAsBc3
    But, there are some workarounds. You can create a widget or set a gesture to open Google Now. Another trick is enabling 'Labs' in Nova launcher and use a long press on home key to open Google Now instead of Search.
    04-26-2017 09:39 AM
  1. Replies: 7
    Last Post: 04-26-2017, 05:09 PM
  2. Replies: 1
    Last Post: 04-26-2017, 08:48 AM
