1. Making progress's Avatar
    The microphone dialog box is really light grey and the instructions are white and I can hardly see them. If I could get the instructions to be a different color or a different contrast that would really help.
    04-27-2017 10:35 AM
  2. N4Newbie's Avatar
    We would need to know what phone model and operating system version in order to answer your question.
    But, more than likely, the answer is "no" unless you are willing and able to root your phone. Even with root, still not an easy thing for a novice to accomplish.
    04-27-2017 10:58 AM
  3. N4Newbie's Avatar
    I should add, I presume you are talking about a system dialog, rather than one coming from a third-party app. If you are referring to an app, then you need to contact the developer.
    04-27-2017 10:59 AM
  1. White light on the edge of my screen
    By Reptar132 in forum Samsung Galaxy S8 & S8+
    Last Post: 09-28-2017, 04:51 PM
  2. Replies: 1
    Last Post: 04-27-2017, 01:37 PM
  3. Replies: 2
    Last Post: 04-27-2017, 12:32 PM
  4. Reverse engineering: how can i lock my device with finger?
    Last Post: 04-27-2017, 10:25 AM
  5. Replies: 0
    Last Post: 04-27-2017, 09:53 AM
