1. Dan BC's Avatar
    I want to test an app with an older versions of Chrome to see the behavior.
    Where can I find old APKs for Chrome?
    And how to install them...do I need to uninstall Chrome from the phone first?
    05-01-2017 04:03 PM
  2. jasonandrews25788's Avatar
    05-01-2017 08:14 PM
  3. sethyboy's Avatar
    Aptoide also works with no root. http://en.aptoide.com Just make sure Unknown Sources is enabled on your phone. Also, watch out for any fake apps that might be on there; I'd recommend you have an antivirus program ready.
    05-02-2017 12:03 AM
  4. Dan BC's Avatar
    Tried aptoide but am getting "uninstall unsuccessful" when I try downgrading Chrome. Guess I need to root the phone first.
    05-02-2017 09:39 AM
  5. sethyboy's Avatar
    That's strange because it works fine on my Samsung tablet with no root. I would just try uninstalling updates from Settings > Apps and then installing the version in Aptoide.
    Also, if your phone came with Chrome preinstalled as a system app, I don't think you can downgrade it lower than the version it came with (unless, of course, you root).
    05-02-2017 11:02 AM
  6. Dan BC's Avatar
    I think this is what I'm seeing. It's preinstalled even when doing a factory reset. I soft bricked the phone while trying to root it though .
    Hopefully can fix it and downgrade Chrome.
    05-02-2017 11:33 AM
  7. Dan BC's Avatar
    Well, I rooted an S4 but no luck on getting older versions of Chrome working.
    I can install with aptoide but when I try opening the app there is an error "Unfortunately, Chrome has stopped". Clearing the data and cache of Chrome doesnt help.
    With apkmirror I can't even install it - "Install failed".
    Are there other options for installing old Chrome versions?
    05-03-2017 11:06 AM
  1. Success with android data recovery with Jihosoft or Dr. Fone?
    By Ariel Balter in forum General Help and How To
    Last Post: 09-14-2017, 09:58 PM
  2. can't find my keypad to make phone calls
    Last Post: 05-01-2017, 08:40 PM
  3. Replies: 3
    Last Post: 05-01-2017, 04:48 PM
  4. Replies: 1
    Last Post: 05-01-2017, 04:33 PM
  5. Why are some of my pictures covered in gray.?
    Last Post: 05-01-2017, 03:44 PM
