1. Willsamsung's Avatar
    Hello! New user here.
    Been a long time samsung user now but this is my first major problem. So I recently realised the s7 edge which ive had for about 1 year, when I use it In the morning after charging says the usual (something along the lines of) please use swipe pattern, samsung restarted etc. (The usual message you'd recieve when the device restarts) It seems to happen almost everytime, about 10 minutes into the charge, wether plugged in, or wirelessly charging. Now, it doesnt appear to be a 'full restart', the samsung screen never appears, only the 'unlocking symbol'. Takes all of 10 seconds to restart rather than the usual 30 or so.
    This wouldn't bother me as its just a simple restart while I'm usually sleeping. However, I now notice my samsung sd card 128gb has been corrupted when I wake up, probably due to the sudden restart thats occuring. (Thank god I have recovery software and was able to recover all of my files on the sd card before a re format). Woke up this moring. Same thing again.
    WHAT IS GOING ON!
    The SD card continues to work for a few days, a week or 2 maybe. Then corrupted again (while the phone continues to restart itself every single night without fail).
    Note: seems to only have started since around the 7.0 update I believe. Problem has been happening since around that time
    Help to this issue is much appreciated
    05-09-2017 08:23 AM
  1. Stop menus from popping up while talking on the phone
    By KennyKans in forum Ask a Question
    Last Post: 05-09-2017, 10:54 AM
  2. S7 edge restarts while chargine-sd corrupts
    By Willsamsung in forum Samsung Galaxy S7 edge
    Last Post: 05-09-2017, 08:34 AM
  3. SD card as internal storage error
    Last Post: 05-09-2017, 08:00 AM
  4. Weather Cards Gone ?
    Last Post: 05-09-2017, 07:44 AM
  5. Why can't I move my apps onto my new SD card?
    Last Post: 05-09-2017, 07:37 AM
