1. LegoHead07's Avatar
    God! This has been bothering me for hours. I've never had an issue with the stock Samsung music player, but I just realized that if you accidentally put too many periods in the name of a song/album/artist then you can never change it back.
    To go into more detail, you can change a title usually just by editing it, but if you put periods after the name then the music player won't let me reverse it. It says when I edit it that it's fine, but then when I look at it on the screen it isn't fine.
    For example, I wanted "Mm.. Food" as the album name, but I accidentally put two periods at the end of the album name to make it "Mm.. Food.." which is not how I want it. It says it fine when I edit it, but it isn't. Now, I can change it to anything else in the world and it will be good, but as soon as I do "Mm.. Food" in particular it always adds the two extra dots. Itag doesn't let me change this and it really sucks because this even affects the coverart app that I use. How do I fix this?
    05-10-2017 05:06 AM
  2. B. Diddy's Avatar
    Moved from the Android Apps forum to the General Help forum, since the former is intended for developers to promote their apps.
    05-10-2017 01:53 PM
  1. My Note 4 can't boot normal..
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 05-26-2017, 10:47 PM
  2. Replies: 1
    Last Post: 05-10-2017, 02:28 PM
  3. How to fix these samsung s8 problems.
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 05-10-2017, 08:41 AM
  4. I have a galaxy s7 and I can't send text messages
    Last Post: 05-10-2017, 03:57 AM
  5. Samsung s7 screen time and lock time problem
    Last Post: 05-10-2017, 02:23 AM
