1. j stubbs's Avatar
    My phone is a Defender 2 with android 5.1 lollipop. I cannot add speed dials but several have appeared on there own. When I look in the contacts list these numbers have a star in the box which enables me to add or remove them from speed dials. The rest of the numbers in contacts have no star meaning I cannot add or remove them from speed dials
    05-13-2017 09:05 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Have you tried adding the contact similar to a widget? Do a long press, and select widgets.
    05-13-2017 10:27 AM
  1. It is possible to use multiple joysticks on Android device?
    By ThomasKK in forum The Gamer's Lounge
    Last Post: 06-06-2017, 12:01 PM
  2. Find My Mobile Not Working / How To Access Cloud From Win 7 PC / Cloud Backup
    By Robert Lindsay in forum Samsung Galaxy S7 edge
    Last Post: 05-17-2017, 03:52 PM
  3. Replies: 0
    Last Post: 05-13-2017, 07:42 AM
  4. How to support NFC in android emulator?
    Last Post: 05-13-2017, 07:26 AM
  5. Replies: 2
