1. vladimir79's Avatar
    Couple of days ago I suddenly lost 4g connection. Nothing helped. Reset, hard reset. I only had 3G when I switch in settings. As soon as I return to 4G icon disappears, and no internet. I still had signal and could make calls and send SMS.
    Then I put 4G card from phone and everything worked.
    Then I changed my Tab SIM for a new one. Nothing.
    Everything was the same, but what is weird is that the card that doesn't work in Tab works in my phone. I have 4G. But not in my Tab.
    Did anyone else encountered something like this?
    My last option, if not, is to go again to my carrier and see if there are other APN settings to use or to change number for a new one.
    05-14-2017 07:15 PM
  2. Tim1954's Avatar
    Call them up on a different phone and go through the settings with them
    05-15-2017 12:24 AM
  3. vladimir79's Avatar
    Forgot to mention that this happened after upgrading to 7.0 for Tab S2. After hard reset nothing changed.
    I'll see what they'll tell me today at service center.
    Still weird that SIM from Tab works in phone, and SIM from phone works in Tab. But, SIM from Tab doesn't work in Tab on 4G.
    05-15-2017 04:54 AM
  4. vladimir79's Avatar
    It's Nougat.
    Downgraded to 6.0.1 4G works perfectly.
    Upgraded to 7.0 it doesn't work at all. Only 3G.
    05-16-2017 03:43 PM
  1. Replies: 1
    Last Post: 05-15-2017, 12:36 PM
  2. How can i fix this problem
    Last Post: 05-14-2017, 07:56 PM
  3. Doogee F5 google play services problem
    Last Post: 05-14-2017, 07:49 PM
  4. Icon problems on Samsung a5
    Last Post: 05-14-2017, 06:41 PM
  5. weather problem
    By Rose5 in forum Android 7.0 Nougat
    Last Post: 05-14-2017, 04:09 PM
