I use CardioTrainer (great app btw) to track my walks and I notice that my other apps that use gps are sucking up the same amount of battery juice. The other apps are CoPilot and the dreaded ATT Navigator which I don't even use. Are these other apps that aren't running when out on my walks sucking up additional battery or is it just a fluke of the battery app (battery indicator) reporting the gps usage to 3 different programs? All 3 gps programs use the same percentage of battery power.
Thanks,
Bryan
Thanks,
Bryan
