[GUIDE] Free VOIP using Google Voice and Groove IP
Takenover83
499
76
Introduction
Groove IP makes things simple. It cuts out the need for several programs or services. You no longer need to use Google Call Back (GV callback/Voice+), a SIP Provider (sipgate) or Sip Client (sipdroid/csipsimple). The downside? It's not a totally free solution. See below for what you need.
Requirements
  1. A Google Voice account (Free)
  2. Groove IP (Cost $2.99)
Google Voice Setup
  1. Sign up for a account if you do not already have one. Google will give you a local number.
  2. Once Signed in, click the Settings Gear icon in the top right corner. Image
  3. Make sure your Google Voice is not forwarding to any other phones. I have mine set to forward to Google Chat/Gmail. Image
Groove IP Setup
  1. Purchase the app and install it on your android phone.
  2. Sign in with your google voice account.
  3. There are various preferences when clicking the Settings button.
Note #1: Have problems with the party not being able to hear you? Go to Settings>Troubleshooting, and enable the Audio Routing Hack.
Note #2: The app is still under heavy development.
Note #3: A update was released to help with audio routing issue's.
Add new settings in troubleshooting to fix call quality on some phones (If you have stuttering/choppy voice try the new Audio Processing settings)
Superorb
232
8
So this works for calling out without requiring GV to call back the phone?
I have an App called Nettalk which is free outgoing calls, but I can't receive calls. I'm fine with that since I only have wireless at home.
Superorb
232
8
Thanks for this, voice quality is pretty good compared to netTalk that I was using before. I was having problems where the person on the other end could barely hear me talking when they were on a landline, but I can adjust the mic gain on this app. The only problem I have is that it will drop wifi/3g after a few seconds when I call out. I also run GreenPower, and it doesn't do this with GP off.
baseballfanz
359
73
Yes Groove is on with green indicator. Call my GV # and it would ring than go to vm.
I can use groove to do out going no problems
Superorb
232
8
There's a setting in Groove that has to do with pushing 1 when you answer a call to send it to voicemail. Maybe try checking/unchecking that box and see if that helps.
baseballfanz
359
73
Read somewhere that I have to log out of all my Gmail accounts elsewhere.
Still didn't work but a fresh new GV # and now incoming calls is working.
Superorb
232
8
I'll keep that in mind if incoming calls for me doesn't work.
Have you tried calls on 3g only? I'm only sticking to 3g right now.
baseballfanz
359
73
Make sure Gmail/Google Chat is not open somewhere. I heard that causes problems,.
I read that too and closed every Gmail/Google account I can think of.
Still no go so I use a different GV account and it's working great.
To test the theory I left a few Gmail/Google account of the new GV # open and
it's still working fine. Don't know what it is that my other GV # didn't work for incoming.
steve1084
