1. sw33ndawg's Avatar
    Recently dropped and cracked the screen on my new Atrix . Unfortunately I don't have insurance so I'm out of luck. Can anyone recommend a good screen repair company? THe cheapest I can find is Motorola Atrix Screen Repair - $99. Does anyone know if this company is reliable? Thanks.
    04-29-2011 08:27 AM
  2. srkmagnus's Avatar
    for Motorola MB860 Atrix 4G New Replacement LCD Screen | eBay
    It's slightly cheaper but shipping may bring it close to $99. It's also being shipped from Hong Kong, not sure if that really matters to you. Good luck
    04-29-2011 08:41 AM
  3. sw33ndawg's Avatar
    I don't want just the screen, need the repair. Thanks for trying though!
    Sent from my MB860 using Tapatalk
    04-29-2011 06:11 PM
  4. srkmagnus's Avatar
    Ah, skipped right over the repair part. sorry about that. Good luck on your search.
    04-29-2011 07:03 PM
