1. garybeckvt's Avatar
    Hello!, my screen comes on automatically all the time which results in many pocket calls and pocket texts. I need to disable this "feature!"
    I did some research and found it is called Ambient Display and it is supposed to be in Settings > Display but it is not there on my phone!?!?!?!?!?!?!?! (Galaxy S5)
    please tell me how I can prevent my phone from automatically turning the screen on all the time !
    thank you
    gary in vermont
    06-04-2017 03:36 PM
  1. Difference in lock screen
    Last Post: 06-04-2017, 07:27 PM
  2. How to require a password every time I turn it off
    Last Post: 06-04-2017, 04:31 PM
  3. why don't the email apps collapse the folders anymore ?
    Last Post: 06-04-2017, 03:01 PM
  4. Replies: 0
    Last Post: 06-04-2017, 02:55 PM
  5. Cant play video on twiter says an other app is using audio
    Last Post: 06-04-2017, 02:43 PM
