1. Advaitom's Avatar
    I'm using Nexus 5x with N 7.1.2. Suddenly my Internal Storage is almost full. I went to Settings -> Storage and I see that the Other storage category has 15gb. When I look at the directories in Other they don't nearly add up to 15gb. How can I see all the files that are in Other? Are there hidden files? How can I see them?
    Thanks,
    06-18-2017 10:50 AM
  2. Golfdriver97's Avatar
    Out of curiosity, I looked at my 5X. I have 18 GB in System. I'm half tempted to do a reset to see if that will reduce that amount.
    06-18-2017 11:28 AM
  3. Advaitom's Avatar
    Mystery solved. By chance and good luck I found out that my Android Recycle Bin had 12GB of files that I thought I had deleted. Wow. I had no idea that there even was a Recycle Bin. I emptied it and now all is well.
    06-18-2017 11:33 AM
  4. Golfdriver97's Avatar
    Neither did I. How did you find it?
    I went ahead with my reset and the System stats are back down to 4 GB.
    06-18-2017 11:37 AM
  5. Advaitom's Avatar
    Upon reflection I'm pretty sure this Recycle Bin is a feature of the ES File Manager and not part of Android. I found this Recycle Bin in ES File Manager.
    Mr Mendelli likes this.
    06-18-2017 08:18 PM
  6. Golfdriver97's Avatar
    06-19-2017 07:27 PM
  1. Replies: 9
    Last Post: 06-23-2017, 11:04 PM
  2. My contacts just disappeared
    By Lindahoskin in forum General Help and How To
    Last Post: 06-20-2017, 03:25 PM
  3. How do i get to the songs on my sd card?
    By San42 in forum Ask a Question
  4. How to get to my music on the sd card
    Last Post: 06-18-2017, 11:31 AM
  5. How do I change email font colors on my galaxy 7
    Last Post: 06-18-2017, 10:48 AM
