1. NiteOwlGrowls558's Avatar
    There is a tiny grey dot on the middle close to the bottom of my screen. Inside the dot is a really tiny white dot and more really tiny white dots inside around the dot if you have a black background behind it. Idk why it is there and idk how to get rid of it. I have a samsung galaxy j7 (2015). Please help.
    06-22-2017 05:34 PM
  2. belodion's Avatar
    Welcome.
    If you rotate the device, does it rotate with the screen?
    06-23-2017 04:53 AM
  3. Chloes dad's Avatar
    Welcome.
    Its does stay there when you rotate the screen. It also goes away when the lock screen is on
    07-15-2017 03:34 AM
  4. Chloes dad's Avatar
    I have that little grey circle too. It does rotate with the screen and goes away on the lock screen
    07-15-2017 03:35 AM
  5. Chloes dad's Avatar
    I have looked all over for the solution
    07-15-2017 03:39 AM
  6. Tim1954's Avatar
    A screen shot would help mightily... :-)
    07-15-2017 03:39 AM
  7. robbiehenze's Avatar
    The little dot appears when the Xbox or Xbox beta app is running. At least for me it's what it meant. Hopefully this helped you.
    08-03-2017 08:37 PM
  8. Lucas Bingley's Avatar
    I also have this dot on my screen with only the Google app open..
    Attached Thumbnails How do i get rid of this tiny grey circle on the bottom of my screen?-screenshot_20170804-124932.png
    08-04-2017 11:51 AM
  9. Lucas Bingley's Avatar
    It's at the bottom of the picture.. I have a Cat S60 phone
    08-04-2017 11:52 AM
  10. Sham_rock's Avatar
    See attached. It's on every screen I go to. Even camera. Right side of screen
    Attached Thumbnails How do i get rid of this tiny grey circle on the bottom of my screen?-15137047063261355928592.jpg
    12-19-2017 11:33 AM
  11. Sham_rock's Avatar
    Left side duh
    12-19-2017 11:34 AM
  12. swanny78's Avatar
    It the xbox app being allowed to run over other apps. You can disable in apps settings.
    03-26-2018 02:05 PM
  1. Replies: 4
    Last Post: 11-03-2018, 04:47 PM
  2. Replies: 8
    Last Post: 06-24-2017, 07:14 AM
  3. Hi im deaf n my name Zenobia Mashigo
    Last Post: 06-23-2017, 05:27 AM
  4. how to set password
    Last Post: 06-22-2017, 04:31 PM
