Nexus 6P running 7.1.2 with Gboard, Swiftkey and Flexsy keyboards, have a jibberish typing issue. No matter the keyboard I use, it will randomly throw letters in that are no where near where I am typing. I can type slow and for example, hit the letter a and a P M E and O might pop on the screen. Then when I hit the backspace button to delete those random characters, the back button will go back a little and randomly throw in letters also. WTH?
It does this will all three keyboards I have installed and I also installed a few others to test and the same problem. Any ideas? It has done this the last few months and is getting worse. So its not the latest update. I am almost at the point I have to use voice to type on it.
Bad digitizer? I hate to do a fresh reboot as I have learned over the years that it has only helped about 20% of my issues in the past. Usually, I go through setting my phone back up again, only to have the same problem.
Any help or ideas?
Thank you.
Any help or ideas?
Thank you.
