1. anon(3900582)'s Avatar
    Hi,
    I have a Galaxy Note 3 running Lollipop 5.0.
    When I select any ringtone that sounds perfectly fine when previewed in the list of ringtones , when the phone rings, the volume is almost inaudible for the first 2-3 seconds and then goes up to its normal expected volume.
    I've tried with many ringtones both stock and custom with the same result.
    Any suggestions on what can be causing this ?
    Thanks
    07-11-2017 07:52 PM
  2. Tim1954's Avatar
    Open one of your alarms, find ringtone... Tap on that, tap volume... You should have a setting "gradually increase volume"... Toggle that off and Bob's your uncle! :-)
    07-11-2017 08:01 PM
  1. Got a few problems
    By GNS1310 in forum HTC 10
    Last Post: 07-14-2017, 06:51 PM
  2. Replies: 1
    Last Post: 07-12-2017, 05:21 PM
  3. Replies: 0
    Last Post: 07-11-2017, 07:49 PM
  4. How to activate my emoji text in my asus phone
    Last Post: 07-11-2017, 07:12 PM
  5. Phone shuts off when I touch it
    By AC Question in forum Motorola Droid Turbo 2
    Last Post: 07-11-2017, 06:18 PM
