Battery life much better as the days progress - you are a genius!
As for the 'not showing contact names only numbers' issue - I use my desktop PC to add/amend my Google contacts which are linked to my phone as it's simpler for an 'oldie' such as myself. Is there any convention for ensuring that, when calling another Android phone you name appears on their phone and visa versa (assuming that both contacts are in their contacts list)?
I have tried everything with no success on both my Smart Ultra 7 and my wife's Motorola Moto G (4th) - any help appreciated!
Again, sorry for the late reply....
My IQ is only a 125....so MENSA isn't exactly beating my door down for me to join...lol.
But seriously, I've been around the Android scene a while and after flashing a good 50 to 75 ROMs for various devices, it all becomes a pattern.
After a reset or update, it's kind of like using a new phone all over again. With updates the kernel most often gets one too. The kernel helps direct software request to hardware, and vice versa. So for example you turn your volume up, either by a physical key or the virtual one, and the volume goes up, there was activity in the kernel. I don't know exactly what happens in the background, but it usually clears up in 3 to 5 days.
As for the contact info....the only thing I can think of is to double check on desktop, and then force a sync to Google. You can do this in Settings>account>Google. If need be, I can show you the path if it were a Pixel. The exact place may differ from yours, but you will get the idea.
Also, for faster responses, you may by all means quote me. That can go for any user. Quoting me will send a notification (technically several) and I will see it. It may be the next morning, but I'll see it.
