1. LeadedRiver's Avatar
    My Alcatel id 4 is taking screen shots when I'm on Google or on chrome it takes repeated screen shots and won't stop until I go to the home screen its my boom key that I think is doing it I checked my setting and stuff the easy way is to enable screenshots from my boom key but I still want to be able to take screenshots using the boom key and when ever I try to use the button to take a screenshot it won't do it I was in the rain with my phone so I don't know if that has anything to do with it any help would do
    08-02-2017 06:32 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! So if you change the Boom Key function to something else besides screenshot, does this problem go away? If you change it to Trigger Application, does it constantly open that app? If so, then the key itself is probably damaged by moisture, and is constantly in a pressed state. You'd probably have to get the button replaced by a repair shop.
    08-02-2017 06:58 PM
  1. Replies: 2
    Last Post: 09-08-2017, 06:04 AM
  2. Replies: 12
    Last Post: 08-17-2017, 03:22 PM
  3. Replies: 1
    Last Post: 08-02-2017, 07:01 PM
  4. Replies: 1
    Last Post: 08-02-2017, 07:00 PM
  5. Sim card not working on lg escape 3
    Last Post: 08-02-2017, 06:59 PM
