1. DinoRockStar11's Avatar
    My Phone Is A LG Aristo And Is Version 7.0 And When I Go Into My Camera There Is A Dash On The Flash Button Like This / And When I Try To Click It,It Wont Work Please Help Me..
    08-17-2017 03:41 PM
  2. SpookDroid's Avatar
    Are you on any Auto Modes or something? If you use a flashlight app, does the flash work there? If you rotate the camera so that the flash icon is in a different screen spot, can you change the flash mode? Also, most phones restrict flash operation to having more than 15 or 20 percent battery left, so make sure you have more than that or you won't be able to use it.
    08-17-2017 05:12 PM
  1. Moto Z and 360 Camera Needs Update Before It Can Work :<
    By Brian Baldwin in forum Moto Mods
    Last Post: 08-18-2017, 11:02 PM
  2. Why does my WiFi have a time out?
    Last Post: 08-17-2017, 04:33 PM
  3. Why does my phone keep udating?
    Last Post: 08-17-2017, 03:54 PM
  4. Can't hear my gps how to fix it?
    Last Post: 08-17-2017, 03:01 PM
  5. Wireless headphones keep cutting out when paired to phone
    Last Post: 08-17-2017, 02:42 PM
