1. Asilnelle's Avatar
    I have the lg arista. I am on smule sing after i record my song there is excessive static when listening back to it...i have exchanged it two times with the same results. Can anyone help me
    08-27-2017 06:51 AM
  2. Asilnelle's Avatar
    Three different phones and i have the same static when istening to songs i record on smule sing..that's the only time i have static. Can you help me please
    08-27-2017 07:51 AM
  3. Rukbat's Avatar
    It's either something local (like a microwave oven), smule itself, your earphones (if you're using any) or something else I'm not thinking of. But if it only happens when you record on smule, and not when you record on other things, I'd have to guess it's smule.
    08-27-2017 11:56 AM
  4. Rukbat's Avatar
    From your description, I'd say that either there's something locally causing static (like a microwave oven), or it's a problem with Smule. Contact them at http://www.smule.com/support/sing#android
    08-27-2017 01:06 PM
  1. "Not enough space on phone" notification with 80% storage remaining
    By Gregorio Curello in forum Legacy Android & Other OS's
    Last Post: 08-28-2017, 07:12 PM
  2. why does my Samsung Galaxy s7 edge screen jolt when the phone is lit up
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 08-28-2017, 02:07 AM
  3. Replies: 15
    Last Post: 08-27-2017, 07:13 AM
  4. Why is this symbol always on my phone?
    Last Post: 08-27-2017, 05:57 AM
  5. Replies: 0
    Last Post: 08-27-2017, 05:47 AM
