1. schaidshaw02's Avatar
    My SD card for my Galaxy 7 recently became corrupted. When I had gone to bed the night before it was fine but then the following morning it showed up as corrupted. Everything is back up on the cloud so I'm not worried about getting anything back but I need the card working.
    I have gone to fossbytes.com and went through the options they show to fix the card, and also downloaded Windows EaseUS program but none of the options have worked. Does anyone know of any other options out there that have worked for them or others?
    08-28-2017 11:27 PM
  2. B. Diddy's Avatar
    Moved from the Accessories forum to the General Help forum, since I think you'll get better answers here.
    Insert the card into your computer -- is it detected there? If so, then backup as much as you can right now, then run chkdsk to look for bad sectors: http://forums.androidcentral.com/amb...d-sd-card.html.
    If the PC can't read the card, then it's dead. Remember, SD cards are inherently much less reliable than onboard memory -- even those from well-known brands.
    08-29-2017 02:44 AM
  3. schaidshaw02's Avatar
    it runs through the program saying corruption found, although it does read the card. although it didn't fix the card. is the the last option in trying to fix it?
    08-30-2017 04:20 PM
  4. anon(238680)'s Avatar
    Yes. If it reports corruption but can be read then you may be able to copy some data from it. Have you tried? If you can't then the card is gone.
    B. Diddy likes this.
    08-30-2017 04:29 PM
  1. Replies: 4
    Last Post: 04-25-2018, 12:17 PM
  2. Replies: 4
    Last Post: 02-21-2018, 09:24 AM
  3. SD Card
    By luca19608 in forum Samsung Galaxy S7
    Last Post: 08-29-2017, 02:45 AM
  4. sd card is ready but take too much yime in encryption on j7
    Last Post: 08-29-2017, 12:58 AM
  5. cant mount sd card can you help
    Last Post: 08-28-2017, 12:08 PM
