1. joel567's Avatar
    i heard rooters help but i'm not for sure which one on playstore
    08-30-2017 08:50 AM
  2. jasonandrews25788's Avatar
    if you're running android 5.0+ try magisk method.
    08-30-2017 09:16 AM
  3. Mooncatt's Avatar
    Rooting doesn't help storage, as it only allows greater access to the phone's system files. Granted, you could go in and delete more stuff now, but you also increase the risk of deleting something that causes the phone to glitch.
    I've also seen other members here say those rooting apps can be suspicious in terms of your privacy. I never dealt with them personally.
    So if storage space is your only concern, I wouldn't suggest rooting.
    08-31-2017 01:11 AM
  1. Replies: 6
    Last Post: 01-05-2018, 07:03 PM
  2. Battery Drains by 30% - 40% After Shutdown and then rebooting it again!
    By Yusuf1237 in forum Samsung Galaxy J Series
    Last Post: 09-26-2017, 05:51 PM
  3. my camera is not working
    Last Post: 08-30-2017, 12:55 PM
  4. What does this icon mean?
    By all123456h in forum Ask a Question
    Last Post: 08-30-2017, 08:47 AM
  5. Why is character preview not working on my samsung s6 edge plus.
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 08-30-2017, 07:30 AM
