1. Ishvone's Avatar
    On the LG G5 SE (or on all Android devices), the enter key sends your message with "Go". How can you change that so it creates a new line/paragraph. I've tried to search in the settings, but I can't find anything related to it. Is there a way of changing this, without having to use a third-party app? Thanks.
    08-31-2017 02:35 PM
  2. N4Newbie's Avatar
    Not sure about yours, but on many devices hitting the numeric option (bottom row, far left) will change the Go key (or, is it the the backspace key?) into a Return/New Line key.
    08-31-2017 03:02 PM
  3. Ishvone's Avatar
    I pressed that, and it changes it into a backspace key.
    08-31-2017 03:12 PM
  4. N4Newbie's Avatar
    What about the Shift key? I'm sure that one of them will get you what you need.
    08-31-2017 03:17 PM
  5. Ishvone's Avatar
    The same problem occurs. It remains the same; "Go"
    08-31-2017 03:20 PM
  6. N4Newbie's Avatar
    Well, I can tell you that the Google keyboard ("GBoard" in the Play Store) works as I described - the Shift key turns the Go key into a new line key and it functions as you want.
    So, unless you can find the magic trick on your current keyboard, you may want to download one or two other keyboards (GBoard and Swiftkey would be good choices) and see if you can make out better with one of them.
    08-31-2017 03:27 PM
  7. Ishvone's Avatar
    I'll try it and see how it goes. Thanks for helping me anyway
    08-31-2017 03:35 PM
  1. Charging cable c type plug does not enter fully into my S8
    By asadulhuq in forum Samsung Galaxy S8 & S8+
    Last Post: 11-28-2017, 09:11 PM
  2. Replies: 2
    Last Post: 09-03-2017, 11:33 AM
  3. where is the data in the droid 8+ phone stored
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 08-31-2017, 05:08 PM
  4. My Samsung tablet won't reconnect to internet
    Last Post: 08-31-2017, 03:02 PM
  5. I want to turn the color back to normal color from negative
    Last Post: 08-31-2017, 02:39 PM
