1. Onedeerslayre's Avatar
    I have perused and tried alI the settings and downloaded flash notification and vibrator apps, but maybe the wrong ones. I am in my 60's and still learning so if you make a suggestion please dumb it down including how to use it. Thanks, D
    09-02-2017 01:51 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! You usually can't turn off the battery charging light, unless maybe if you root the phone (which I wouldn't recommend for a novice).
    Some phones have a system setting to turn off the LED Notification light, but it sounds like you've already looked through them. Why does the light bother you? Is it too bright at night?
    09-02-2017 10:41 PM
  1. Ting i got a fee sim and i got some questions
    By Goosinurwife in forum General Carrier Discussion
    Last Post: 02-19-2018, 02:26 PM
  2. Android phones with a removable battery?
    By greg9840 in forum Buyers Guides
    Last Post: 11-20-2017, 07:05 AM
  3. Looking for an app for battery efficiency?
    By fantom555 in forum Samsung Galaxy S8 & S8+
    Last Post: 09-06-2017, 06:45 AM
  4. Easiest way to transfer data. Need help!!
    By scorpio1984 in forum Ask a Question
    Last Post: 09-02-2017, 05:30 PM
  5. Trying to factory reset my Galaxy S8. Unsuccessful!
    By JaneSaidSo in forum Ask a Question
    Last Post: 09-02-2017, 01:46 PM
