1. this_is_nascar's Avatar
    Why would gSam show Facebook as a bigger consumer than Tunein Radio, but the OS shows the opposite?
    gSam has been installed and running quite some time on my Moto Z Play Droid.
    09-07-2017 03:03 PM
  2. this_is_nascar's Avatar
    Anyone, please?
    09-07-2017 08:24 PM
  3. B. Diddy's Avatar
    Moved from the Android Apps forum to the General Help forum, since the former is intended for developers to promote their apps.
    09-07-2017 08:46 PM
  4. this_is_nascar's Avatar
    Thx. Sorry about that. Anyone know why this is happening?
    09-08-2017 07:44 AM
  5. L0n3N1nja's Avatar
    I couldn't tell you why it's happening, but I've often trusted gsam over the information Samsung provides.
    09-08-2017 08:49 AM
  6. this_is_nascar's Avatar
    Thanks for the reply.
    09-08-2017 01:44 PM
  7. this_is_nascar's Avatar
    Anyone else have an opinion on this?
    10-18-2017 11:51 AM
  8. xplod566's Avatar
    It's showing only the apps.so basically the apps which such battery.i guess it's correct
    10-18-2017 01:07 PM
  9. ManiacJoe's Avatar
    Take a look at the gSam settings. There are options for how audio (and video?) are tracked.
    10-21-2017 07:20 PM
  10. this_is_nascar's Avatar
    Thanks. I'll take a look.
    11-18-2017 06:07 AM
  1. How to delete app account in my android device?
    By Cat4phract in forum Ask a Question
    Last Post: 09-07-2017, 02:54 PM
