1. Simon Peter Haukrog Thun Madsen's Avatar
    Hi,
    I just switched from iPhone (back) to the Note. Had the original Galaxy Note and now Note 8.
    I can't seem to figure out how to play music from my Note on my wifi-speakers at home - how and where do I select that I want the music to play on wifi speakers instead of the phones own speaker?
    I must be missing something...
    Btw. I am listening to music using the Google Play Music app, transferred my iTunes library.
    Hope you can help, as I can't believe this should not be possible.
    Regards
    09-19-2017 10:46 AM
  2. SpookDroid's Avatar
    It depends on the speaker that you're using. It needs to be added to your phone, but that depends on each speaker. Some might require a 3rd party app for the configuration. Also check that your speaker isn't only compatible with iPhones.
    09-19-2017 12:25 PM
  1. How do i disable pop up texts messages
    By boriqua2000 in forum Samsung Galaxy Note 8
    Last Post: 12-08-2017, 12:57 PM
  2. Why do I only have the July security patch?
    By rbell2915 in forum Nexus 6P
    Last Post: 10-26-2017, 12:42 AM
  3. Ok the honeymoon period is starting to wear off....
    By ronin_cse in forum Samsung Galaxy Note 8
    Last Post: 09-28-2017, 10:23 AM
  4. Replies: 11
    Last Post: 09-21-2017, 05:39 AM
  5. Replies: 1
    Last Post: 09-19-2017, 03:34 PM
