1. ADI Communications's Avatar
    My phone first and now my Ipads home button is broken am so stressed, Is there a way to fix it my self.
    09-20-2017 05:16 PM
  2. SpookDroid's Avatar
    You can probably get a repair kit and instructions on how to tear them apart and put them back together on sites like iFixit, but if you're not sure about it, just take it to a repair shop...you might end up with an unusable device from a failed repair.
    You can also get 3rd party apps to let you emulate the Home Button on-screen, if you can live without the hardware one.
    09-20-2017 05:25 PM
  3. anon(238680)'s Avatar
    Welcome to Android Central. Unless you're a repair technician, not really as those are most likely soldered to the motherboards. Sorry. Also, please watch the language as we're a family site, I touched up your post a little
    09-20-2017 05:27 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Do you have an Android phone or an iPhone? You mentioned an iPad, which is why I ask. If so, then do you have AppleCare?
    09-21-2017 12:06 PM
  5. belodion's Avatar
    I don’t know about iPads, but the home button on some older iPhones can become troublesome, but is sometimes curable, if done carefully, by cleaning with alcohol on a cotton bud. Enough alcohol runs under the button to have a cleaning effect, or something. I’ve done it myself on an old iPhone 4, successfully.
    B. Diddy likes this.
    09-21-2017 01:14 PM
  1. Just made the Switch from a V10 to the Mate 9!
    By fatproduce in forum Huawei Mate 9
    Last Post: 10-04-2017, 05:39 PM
  2. How to put icon/link on home screen to Gallery Image
    By JARHTMD in forum Samsung Galaxy S5
    Last Post: 09-21-2017, 02:05 PM
  3. How to restrict the wifi data usage?
    By BostonFern in forum Ask a Question
    Last Post: 09-21-2017, 12:29 PM
  4. How similar between HTC U11 and Pixel 2?
    By cnotes2016 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 09-21-2017, 09:57 AM
  5. How to turn off auto correct?
    By h2ofun in forum Samsung Galaxy Note 8
    Last Post: 09-20-2017, 03:44 PM
