1. mayavi's Avatar
    I cant download any app from play store. The downloading icon is flashing away.i cant download from email or googledrive. But there is no issue with chrome.there by no issue with download manager.pls help
    09-30-2017 12:38 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! From your other post, I assume you're asking about your Lenovo K4 Note. Does this happen on both wi-fi and mobile data?
    Try going to Settings>Apps>All, select Google Play Store, and Clear Cache/Clear Data, then Force Stop. Do the same for Download Manager. Now try again.
    If that doesn't work, try going to Settings>Accounts-Google, select your Google account, and remove it completely from the phone. Then add it back again, and see if that helps.
    mayavi likes this.
    10-01-2017 02:21 AM
  3. mayavi's Avatar
    its still not downloading anything...The downloading icon keeps flashing in the notification bar..pls help
    10-20-2017 10:38 PM
  1. What are Amazon 6P owners doing about battery issue?
    By lucidlyseen in forum Nexus 6P
    Last Post: 09-30-2017, 03:22 PM
  2. Samsung Galaxy S7 - screen/icon grid issue
    By aerist in forum Ask a Question
    Last Post: 09-29-2017, 02:57 PM
  3. Replies: 1
    Last Post: 09-29-2017, 10:31 AM
  4. Tab S2 battery pattern (Charging Issues)
    By Jackson Summers in forum Samsung Galaxy Tab S2
    Last Post: 09-29-2017, 08:41 AM
  5. Bluetooth issue .. after 3 months
    By amyf27 in forum Samsung Galaxy Note 8
    Last Post: 09-28-2017, 04:56 AM
