1. Bmilano3161's Avatar
    I had an S6, connected to my 2017 Traverse and played music and Audible without any problem.
    Got a new S8, used same connection and sound only comes through the phone not the car's speakers.
    Any suggestions on what I'm doing wrong?
    Thanks
    09-30-2017 04:03 PM
  2. N4Newbie's Avatar
    You are going to think I am crazy, but are you certain the plug is *all the way in* your S8?
    Is the S8 in a case? Some cases interfere with some audio connectors.
    Also, the jacks on some phones have particularly strong spring contacts inside and require a fair amount of force to insert the plug fully.
    Nostromo79 likes this.
    09-30-2017 05:51 PM
  3. Bmilano3161's Avatar
    You nailed it! That was the problem. Thank umso much. I was going crazy
    09-30-2017 06:31 PM
  4. N4Newbie's Avatar
    Lol. Thanks, but which was it? The case? Or, just not pressing hard enough?
    09-30-2017 07:28 PM
  5. Bmilano3161's Avatar
    The case
    N4Newbie likes this.
    09-30-2017 07:59 PM
  6. njshoremom4gurlz's Avatar
    Ok I'm just using this thing fires fugue out why car usn didn't fit
    10-01-2017 11:09 PM
  1. Oneplus 3T on oxygen OS 4.5.0 playing sound through ear piece
    By Mattimatikern in forum OnePlus 3 & 3T
    Last Post: 10-01-2017, 01:50 AM
  2. how do you turn on edge lighting on my galaxy s8
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 09-30-2017, 04:32 PM
  3. How do I unlock my s8 you get out from under sprint?
    Last Post: 09-30-2017, 02:50 PM
  4. Samsung Galaxy S7 - screen/icon grid issue
    By aerist in forum Samsung Galaxy S7
    Last Post: 09-30-2017, 02:13 PM
