1. newAndroidHappyUser's Avatar
    Hi!
    This might sound stupid, but I am always hitting the wrong key on my Samsung Galaxy S7 keyboard... The phone is almost exactly the same size as my previous iPhone 6S, but I didn't have this problem with the iPhone....
    Not sure if my fingers are too big, or maybe too warm so they trigger the key besides the one I need to hit lol!!!
    Or maybe I just have bad aim, but I wonder why I was typing fine on my iPhone and I just can't get to hit 5 correct keys in a row on my Galaxy...
    Anyone have some type of solution which would make my typing easier???
    Thanks a lot!
    10-01-2017 09:40 PM
  2. stmax's Avatar
    Lol... I hear ya. I so want to use the Samsung keyboard so I can match the theme to my theme on my phone. Not sure why but I just can't use it either. I keep going back to GBoard by Google. I can pretty much type with my knuckles on it and it sorts out what I'm trying to say
    10-01-2017 09:45 PM
  3. chanchan05's Avatar
    You can adjust the keyboard size, or just download a keyboard with better spacing for you.
    The two most popular ones arw Gboard and Swiftkey.
    10-01-2017 09:47 PM
  4. rfan8312's Avatar
    I have all three Gboard, Swiftkey and Samsung.
    I'm typing ok, but I can't type the word 'time' or 'sometimes', ever. I wish the period dot wasn't under the M.
    I only get as far as "so." Then I see it later. 'time' always comes out as to.es.
    It's annoying because it happens constantly.
    Strangely, the best phone I ever had for typing, voice recognition and auto-correct was the Kyocera Hydro. I could just type away and it fixed every word. Or I could speak and it got it all perfectly every time.
    10-01-2017 10:40 PM
  5. newAndroidHappyUser's Avatar
    I'm glad to hear I'm not the only one having typing problems!!
    I'll try Gboard and/or Swiftkey and come back to you and tell you if it helped!
    10-02-2017 12:25 PM
  6. newAndroidHappyUser's Avatar
    Yep!
    Tried Gboard and it is definitely better!
    I am still hitting a few keys wrong once in a while, but nothing compared to the stock Samsung Keyboard.
    Thanks for help!
    10-14-2017 11:30 AM
  7. newAndroidHappyUser's Avatar
    Yep!
    Thanks for help!
    10-14-2017 11:30 AM
  8. rfan8312's Avatar
    Wait can you select to have each letter in a little border? I find that helps alot instead of having all.letters displayed together over black background.
    10-15-2017 12:30 AM
  1. I Got The Note 8!!!
    By Nickerz in forum Samsung Galaxy Note 8
    Last Post: 10-02-2017, 11:01 AM
  2. Replies: 1
    Last Post: 10-02-2017, 12:53 AM
  3. Minecraft worlds lost on new tablet
    Last Post: 10-01-2017, 10:54 PM
  4. notifications do not work with Samsung messages
    By husa3695 in forum Samsung Gear S3
    Last Post: 10-01-2017, 09:24 PM
  5. How do I change the font color on Samsung S6 active?
    Last Post: 10-01-2017, 09:19 PM
