1. TYNKER68's Avatar
    My phone switches from sound to vibrate automatically a lot of the time
    10-08-2017 02:52 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Does it only happen if you put it face down? Does it persist in Safe Mode?
    10-09-2017 05:59 PM
  3. Asif Shahnawaz1's Avatar
    I have same issue with my phone my phone model is A1 Qmobile or geeoni A1 and android 7.0
    12-12-2017 06:28 AM
  4. Asif Shahnawaz1's Avatar
    See if ti goes away after a cache partition wipe:
    12-12-2017 06:43 AM
  5. Asif Shahnawaz1's Avatar
    Wipe cache partition
    Turn off the device.
    Press and hold the Volume up, Home, and Power keys together.
    When the Samsung Galaxy S 6 logo screen displays, release only the Power key.
    When the Android logo displays, release the Volume up and Home keys. 'Installing system update' appears for 30 - 60 seconds, followed by the Android system recovery menu.
    Press the Volume down key until 'wipe cache partition' is highlighted.
    Press the Power key to select.
    Press the Volume down key until 'yes' is highlighted.
    When the wipe cache partition is complete, 'Reboot system now' is highlighted.
    Press the Power key to restart the device.
    If the phone is not working correctly, you may need to master reset it and also clear the cache partition. These two resets clear different parts of the phone storage. Unlike a master reset, wiping the cache partition does not delete your personal data.
    12-12-2017 06:47 AM
  1. Water got into phone speaker and now screen and buttons malfunction
    Last Post: 09-06-2018, 05:44 PM
  2. charging but not logo of Samsung wen try to open Notting
    Last Post: 10-09-2017, 06:03 PM
  3. i forgot my direction lock how to open without loosing data
  4. My Samsung Galaxy J1 Keyboards Won't Pop Up
    Last Post: 10-09-2017, 06:02 PM
  5. how do i retrieve an old Samsung account with my new number
    Last Post: 10-08-2017, 02:25 PM
