1. zaris von malhaven's Avatar
    I have found plenty of ways to set it up to control the media volume by default, but I also want to be able to control alarm volume and ringtone/call volume with the volume buttons.
    I also found an app called buttons remapper that would work, except the free version only allows two actions to be triggered, while I would need 8 (media, alarm, call, and ringtone volume + and -), and it doesn't have options for call or alarm volume.
    If it matters I have an honor 7 lite with android 7.0
    10-13-2017 01:14 AM
  2. xplod566's Avatar
    Use button mapper. It's good
    10-13-2017 01:15 AM
  3. zaris von malhaven's Avatar
    I tried that.
    As far as I can tell it only allows one action per button and the only volume options for buttons work exactly the same as the volume buttons usually do.
    10-13-2017 01:32 AM
  4. zaris von malhaven's Avatar
    [double post removed]
    10-13-2017 01:32 AM
  5. zaris von malhaven's Avatar
    Or could I have some help writing some code to do this for me, if it doesn't exist? The actual code seems like it should be simple, but I'm having a few problems, especially with however the android api works and is documented.
    right now, my xml looks like this: https://pastebin.com/Hz1n2KEw
    and my code looks like this: https://pastebin.com/hH509BH8
    It does what I want, sort of. for some reason it adjusts all the channels at different speeds, and I can't find anything about how to make it change the volume channel at a slower speed.
    I also want to disable the normal action so that call/media volume doesn't change at different speeds depending on when I am doing different things.
    Finally, I have no idea how to make it run in the background. I read something about services, but I did not see any complete examples, and I don't know enough about androids api yet to run what I saw. Does anyone know a good tutorial on how those work?
    Thanks for any help in solving this problem.
    10-13-2017 07:25 AM
  6. zaris von malhaven's Avatar
    10-13-2017 07:25 AM
  7. zaris von malhaven's Avatar
    Nevermind, I figured out how to make a service, but apparently they can't react to button presses for some reason. (Also figured out how to make the volume change a little smother.)
    Except the apps that run in the background that can but don't have the functionality for what I want, no idea how they work.
    10-14-2017 08:53 AM
  8. zaris von malhaven's Avatar
    10-14-2017 08:53 AM
  1. iPhone (4s) Notes app notes to Samsung Notes
    By bialy in forum Samsung Galaxy Note 8
    Last Post: 10-17-2017, 12:38 AM
  2. Unable to UNLOCK my Nokia 6
    By Android Central Question in forum Nokia 6
    Last Post: 10-14-2017, 11:25 PM
  3. Replies: 2
    Last Post: 10-13-2017, 02:46 AM
  4. Replies: 0
    Last Post: 10-13-2017, 01:01 AM
  5. how to upgrade htc wildfire from android 2.2 to latest
    Last Post: 10-12-2017, 11:57 PM
