1. CMB1994's Avatar
    Hello. Thanks for reading this,
    I was charging my phone earlier, but after removing it from charge, a message popped up on my screen saying that neither the Process System, nor the System UI were responding.
    I've tried to reset it by holding down the volume and power button, but I can't remove the System UI message to confirm the reset. Is there any other way to turn off the phone?
    This is quite urgent, as I have a very early alarm in the morning, and I live in a dorm with thin walls. I don't want to wake up the entire hallway due to not being able to switch off the alarm.
    Also, if the UI and Process Systems are not responding, and your phone is frozen as mine is, is it still possible to operate and switch off an alarm?
    Thank you for any advice.
    10-17-2017 06:34 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! For most Android phones, pressing and holding Power for about 15-20 seconds will force a shutdown.
    If the problem persists after rebooting, then see if it happens in Safe Mode:
    Laura Knotek likes this.
    10-17-2017 10:55 PM
  1. S7 Edge Suddenly Not compatible with most of my apps. 10/17/2017
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 12-22-2017, 11:59 AM
  2. Sd card not reading.
    Last Post: 10-17-2017, 09:24 PM
  3. Google Play Music not downloading to SD card
    By LazyLightning in forum Samsung Galaxy S7
    Last Post: 10-17-2017, 03:35 PM
  4. Why will my sd card not work
    Last Post: 10-17-2017, 03:22 PM
  5. LG6 purchased in May 2017. Not turning on and badly heated.
    Last Post: 10-17-2017, 03:19 PM
