1. MRAHILIFTIKHAR's Avatar
    I want to Buy Android smartphone in budget range of Samsung S8. But I'm confuse to which is better between Samsung S7 edge and Samsung S8. Kindly help me out in this matter.
    10-25-2017 12:34 PM
  2. SpookDroid's Avatar
    S8 for sure. If you can afford the S8, I'd go for that one. The S7E is still a great phone, but the S8 builds up on that and improves almost every aspect (even if marginally in some cases). But unless the price difference is outstanding, I'd go for the S8. Just get a case haha those lovely, sexy glass curves are frail!
    MRAHILIFTIKHAR likes this.
    10-25-2017 12:48 PM
  3. MRAHILIFTIKHAR's Avatar
    If Price is matter then which is best between Samsung S7 edge and Samsung S8
    10-25-2017 12:51 PM
  4. SpookDroid's Avatar
    Well, that depends on how much are you wiling to spend or how much you think is worth spending for an overall upgrade. The S8 is the better product. To ME, if I could get an S7E for a couple hundred bucks cheaper than an S8 and I were already spending more than I wanted for the S8, I'd go for the S7E. But if the difference was only 100, for ME, it wouldn't be worth going back and I would get the S8. Again, I don't know what YOUR threshold is, so you'll have to judge.
    These might help...
    https://www.androidcentral.com/samsu...galaxy-s7-edge
    https://www.androidcentral.com/galax...ld-you-upgrade
    10-25-2017 01:02 PM
  1. gettting my xfinity samsung S8 today and case
    By snowboarders in forum Samsung Galaxy S8 & S8+
    Last Post: 10-29-2017, 10:28 PM
  2. what size is the samsung s6 resoultion
    By Android Central Question in forum Samsung Galaxy S6
    Last Post: 10-26-2017, 04:27 AM
  3. Better Between Samsung S7 edge and Samsung S8
    Last Post: 10-25-2017, 01:54 PM
