1. gil_happy's Avatar
    Hi,
    I have an Android media hub (Android 5.1.1) and I'm having a display or web UI question / problem. If you look at the attached screen shot, you can see that app shortcuts are covered up by the + sign. For some reason this just started and I can't figure out how to correct. It was working as expected the other day - when I added apps to the 'desktop' [that were already installed or new ones], the + sign moved to the right and new apps were populated properly. For some reason, the behavior has changed.
    Does anyone know how to fix? Thanks in advance!
    11-07-2017 11:26 AM
  1. Joined to share info on the new Essential PH-1 & general android info
    By messypotamia in forum New to the Forums? Introduce Yourself Here!
    Last Post: 11-27-2017, 07:45 AM
  2. Google Play download manager wont update to Android Oreo
    Last Post: 11-09-2017, 06:08 PM
  3. Not receiving any notifications (CNN app on Android)
    By Peitso in forum Ask a Question
    Last Post: 11-08-2017, 03:24 PM
  4. how to sync windows 10 calendar with SONY ANDROID CALENDAR
    Last Post: 11-07-2017, 02:28 PM
  5. Replies: 1
    Last Post: 11-07-2017, 02:01 PM
