1. Nick1227's Avatar
    I just received an Android TV box T95m, which is connected to my Vizio Smart TV via the internet HDMI, and was following the instructions on this web site above to stream live tv, but, did not work. Thought maybe I am missing something in the equation. After I enable the HDHomerun Client and go back to menu and select TV, I get this popup "you did not set up PVR". Enter add-on browser. When I select this it leads me back to a list of PVRs. Then it shows me that the PVR is enabled. I must be doing something wrong. Any idea? Thanks
    11-18-2017 03:12 PM
  1. How to delete polar bear feather and the little print off my phone
    Last Post: 11-20-2017, 12:23 PM
  2. Powerbeats3 will not connect with galaxy amp prime
  3. Could my s6 active have a virus
    Last Post: 11-19-2017, 01:26 AM
  4. My auto correct has stopped working on my Galaxy
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 11-18-2017, 02:25 PM
  5. My auto correct has stopped working on my Galaxy
    Last Post: 11-18-2017, 01:46 PM
