1. gnarkill283's Avatar
    Why do andriod phone's require decryption on every reboot. I never had to do this on my iphone and seems suspicious. If I use an andriod am I basically handing over all my info to the NSA decrypted for them? I find it strange that when I search for this topic, I find absolutely nothing. Just people confirming that the phone decrypts on start up with no explanation of why this happens.
    11-20-2017 01:55 PM
  2. hallux's Avatar
    On your iPhones did you ever have to enter your pin after a reboot? While it may not have said as much, this was the decryption. Android is doing the same thing.
    Laura Knotek likes this.
    11-20-2017 02:33 PM
  3. pego99's Avatar
    You caused this. Learn how to spell.
    11-20-2017 09:00 PM
  4. Rukbat's Avatar
    It's encrypted so that if someone "finds" your phone, they can't get your data. The only way the phone knows that it's you is when you put in the "decryption" code.
    The NSA has nothing to do with it. Your phone calls, texts and emails aren't encrypted.
    11-21-2017 07:48 PM
  5. woodmonkey's Avatar
    It's just a way to protect privacy when others finds your device.
    11-21-2017 09:06 PM
  6. chanchan05's Avatar
    I think you have a misunderstanding of encryption/decryption if you think NSA has anything to do with it.
    11-21-2017 09:07 PM
  1. Replies: 2
    Last Post: 11-20-2017, 03:33 PM
  2. The alert for incoming texts stopped working. The volume is on. How do i fix it
    Last Post: 11-20-2017, 02:53 PM
  3. Why does my note 10 keep shutting down and restarting on its own
    Last Post: 11-20-2017, 01:58 PM
  4. why does my google playstore not let me install apps anymore
    Last Post: 11-20-2017, 01:57 PM
  5. How can i enable a required permission i cant delete contacts from my phone
    Last Post: 11-20-2017, 01:56 PM
