1. Hsloell's Avatar
    I am not having any success downloading photos from text message. I press and hold and nothing happens. I have a ZTE blade . Any idea why or how I can save photos?
    11-24-2017 01:53 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you long pressing while you're still seeing the whole message thread, or are you tapping the photo first to expand it, and then trying to long-press it? Make sure you're long-pressing while you still see the whole message thread. If you've expanded it to fill the screen, you need to look for the Save or Download option in the menu options instead.
    11-24-2017 02:11 PM
  1. How to Shut Off Google?
    By recDNA in forum LG V20
    Last Post: 12-04-2017, 12:51 AM
  2. Whatsup images downloading failed
    By Android Central Question in forum Android Apps
    Last Post: 11-26-2017, 01:07 AM
  3. Referencing a CSS file in HTML on Android 6
    By Raabi Anony in forum Ask a Question
    Last Post: 11-25-2017, 05:41 AM
  4. Private mode fails to turn on after update
    Last Post: 11-24-2017, 02:12 PM
  5. Replies: 1
    Last Post: 11-24-2017, 01:15 PM
