[MEGATHREAD] In coolpad note 5 fingerprint app and setting option is missing
Status
Not open for further replies.
A
AC Question
Hlw frnd, I'm Nakul my contact no. [removed] frnds mere pas Coolpad note 5 mobile ek din isme setting mai se fingerprint lock ka option ka gayab h gya i did reset again n again but fingerprint lock r not come back I am very sad pls any one help me
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,362
245
63
Re: In my Coolpad note 5 finger print app is Missing and i cant use finger print please help me
Without feedback to suggestions already made, this thread is going nowhere. I'll close it therefore, and suggest contacting the manufacturer's customer support.
A
Android Central Question
Why is my finger print app missing?
When I do the finger print touch at the back also it doesn't respond any and my phone won't unlock, and also the finger print app missing from my phone(Coolpad note 5)
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,285
4,401
113
Re: fingerprint recognition app missing from coolpad note 5 please help
Welcome to Android Central! I moved this from the Android Apps forum to the General Help forum, since the former is intended for developers to promote their apps.
Are you saying that it's not an option in the system settings, under Lock Screen & Security?
A
Coolpad Note5 Missing fingerprints app delete
Coolpad 36001 My fingerprints app is delete setting please help......
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,285
4,401
113
I merged a number of similar threads together. It seems like this is a common issue with Coolpad phones. The best thing to do may be to contact Coolpad themselves and see if they are aware of the issue.
belodion
Moderator
Jun 10, 2014
39,362
245
63
Thread closed. All help that can be offered has been offered. Without feedback about those suggestions we can go no further.
Edit 13th August:. See the suggestion in Post 3 here: https://forums.androidcentral.com/showthread.php?t=893890
Thread re-opened to allow feedback to that suggested fix.
A
fingerprint sensor is not working
in my coolpad note 5, the fingerprint sensor is not working. if i go to the settings and check then there also i did not found any option for the fingerprint setting.
belodion
Moderator
Jun 10, 2014
39,362
245
63
Re: fingerprint sensor is not working
We've had posts about this from others. There seems no obvious answer. Contact the manufacturer's customer support.
A
My coolpad note 5 finger print app is missing how can I get it back
belodion
Moderator
Jun 10, 2014
39,362
245
63
Re: My coolpad note 5 finger print app is missing how can I get it back
This has been asked before and we have no solution. Contact the manufacturer’s customer support.
A
In my coolpad note5 fingerprint app is missing
I could not use fingerprint because that option is completely gone
A
Why Fingerprint app missing in my mobile ?
I have a Coolpad note 5 mobile phone ...just now the fingerprint app missing from setting ...it is a in bulit app can help me
Status
