[MEGATHREAD] In coolpad note 5 fingerprint app and setting option is missing
Status
Not open for further replies.
A
AC Question
Hlw frnd, I'm Nakul my contact no. [removed] frnds mere pas Coolpad note 5 mobile ek din isme setting mai se fingerprint lock ka option ka gayab h gya i did reset again n again but fingerprint lock r not come back I am very sad pls any one help me
A
Android Central Question
In my Coolpad note 5 finger print app is Missing and i cant use finger print please help me
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
A
Why finger print unfortunately stopped
In my mobile coolpad note 5
The finger print locker was not working and system shows
The finger print locker was unfortunately stopped
what can I do for this?
Give me some solution for this
Aug 13, 2018
Re: In my Coolpad note 5 finger print app is Missing and i cant use finger print please help me
Just go to lock screen&setting - tap on screen lock option- and select option "None". Then the message will appear that this will disable pattern as well as finger lock(Just click OK). Now done. Now you can make new finger scan as well as new pattern or slide lock. Hope this will resolve your issue.
Mkrishna1987
Fingerprint app is missing and sensor not recognised
Hi, I'm using Coolpad Note 5 for above 1 year. Suddenly fingerprint app is missing in my device. Then fingerprint sensor also not working. Please anybody tell me the possible solutions to solve this problem...
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,389
254
83
Re: Fingerprint lock app missing for setting option
Thread reclosed because there has been no helpful feedback to the fix suggested above, nor indeed feedback to any of the help and suggestions offered in this thread.
Status
fallingOutOfLoveWfithTech
