1. Ladyalice08's Avatar
    It just shuts off when it hits around 40%. After that i cant turn it on unless i plug it in the charger. Once conected it shows 36% and I already changed the battery. Help !
    12-03-2017 02:04 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! You changed to a new battery, or was it used?
    Ladyalice08 likes this.
    12-03-2017 09:27 PM
  3. Ladyalice08's Avatar
    I bought a new one. I threw out the first one thinking that was the problem. So i bought a new one and it does the same thing
    12-04-2017 12:37 AM
  4. B. Diddy's Avatar
    First, see if this happens in Safe Mode: https://support.t-mobile.com/docs/DOC-30290. If it does, then try wiping the cache partition: https://support.t-mobile.com/docs/DOC-30305.
    If neither of those help, then it might be time for a factory reset. If even that doesn't work, then the last thing to try before bringing it to a repair shop (or contacting Samsung, if it's still under warranty) would be reinstalling the firmware using Smart Switch (http://www.sammobile.com/forum/showthread.php?t=29914) or Odin (http://forums.androidcentral.com/amb...interface.html).
    12-04-2017 02:30 PM
  1. Does Essential have a sure future?
    By dlalonde in forum Essential Phone
    Last Post: 12-10-2017, 01:34 AM
  2. Samsung pop up
    Last Post: 12-04-2017, 06:09 AM
  3. Wht is my samsung + stopped working for my samsung galaxy phone please explain
    Last Post: 12-03-2017, 09:40 PM
  4. Android System Frequently Crashes (Samsung S4)
    Last Post: 12-03-2017, 09:31 PM
  5. Replies: 0
    Last Post: 12-03-2017, 01:31 PM
