1. Rover775's Avatar
    Okay, I'm not actually selling the phone, but donating the phone.
    I have an LG Motion MS770 that I got from Metro PCS that I no longer use. I want to donate the phone to a local group.
    4.0.4
    I did the Factory Reset.
    I have removed the sim card and SD card.
    But in Settings/ About Phone/ Status
    it still displays my phone number.
    I do not want my phone number on the phone when I donate it.
    Is it possible for me to do something that would have "My phone number" to be blank??
    12-03-2017 07:45 PM
  2. B. Diddy's Avatar
    Did you also remove your Google account from the phone? After you did the factory reset, did you go through the Setup Wizard again in order to look at the Settings>About Phone menu? After a factory reset, it shouldn't just dump you back into the homescreen -- that would suggest to me that it wasn't fully factory reset.
    What happens if you do a hardware key factory reset as described here? LG MS770 Motion 4G - How to Hard Reset my phone - HardReset.info
    12-03-2017 08:27 PM
  3. Rover775's Avatar
    After I did the Factory Reset, I did have to go through the set up wizard to look at the Settings Menu.
    The hardware key factory reset instructions were somewhat vague to me, so I have no confidence in following them.
    Here's an example:
    Tap Power button to switch off device.
    If I tap the power button, the screen goes dark, but the phone is not really off, unless I press and hold the power button, and then an option screen appears to "Power Off". So who knows what they actually mean by switch off...
    When LG logo will appear on screen release buttons. -- Is that even an English grammar sentence??
    Confirm process twice by pressing Power button.
    Press and hold the Power button, or just press and release the Power Button? How does doing that = confirming twice??
    So, I hope you see my confusion with those instructions.
    But thanks, anyway B. Diddy
    12-03-2017 09:43 PM
  4. B. Diddy's Avatar
    Sorry about that link. This video is better:
    Did you actually reenter your Google account information when you went through the Setup Wizard again? Or were you able to skip that?
    Rover775 likes this.
    12-03-2017 10:26 PM
  5. Rover775's Avatar
    I was able to skip that. In Settings, under Accounts & Sync, the page is blank, with no accounts listed.
    I was able to do the Hard Reset. It took me several attempts at pressing the Home & Back Button keys together repeatedly to get the big green android to come up.
    I also had a 2nd LG Motion that I forgot the PW to. I did the same procedure, even with no vibrate on start, and it worked, and the green android came up. After the reset, the phone was unlocked.
    But.... for Both phones, after the Hard Reset, the phone numbers Still appear in the About Phone area.
    I am going to take the phones to Metro PCS to see what they can do.
    Thank you for the YouTube link B. Diddy.
    12-04-2017 06:29 AM
  6. B. Diddy's Avatar
    Interesting -- I agree with bringing the phone to MetroPCS. If you had a phone on a CDMA network (like Verizon or Sprint), then it'd be less surprising that the phone number was still there, since I think the provisioning happens on the carrier side for those phones. But for GSM networks, I would have thought it is entirely up to the SIM card.
    12-04-2017 01:58 PM
  7. B. Diddy's Avatar
    I was thinking more about this -- that phone actually is a CDMA phone, from back when MetroPCS was a CDMA network (prior to merging with T-Mobile, a GSM network): LG Motion 4G, MS770 | LG USA. CDMA phones have to be provisioned by the carrier (rather than just popping a SIM in). So I'm guessing the phone number is stuck there due to the provisioning. Since it's been years since MetroPCS was a CDMA network, I'm not sure if they'll be able to get rid of it, but it's worth a try. Good luck!
    12-04-2017 02:16 PM
  8. Rover775's Avatar
    Right, the 4G LG Motion was a CDMA phone. I hadn't had it for that long when they announced they were going to the GSM network in about 7 months. That's when I upgraded to the Huawei Vitria.
    I'll let you know what Metro says. I'll get there in a few days.
    B. Diddy likes this.
    12-04-2017 11:34 PM
  1. Google Play Music-keep on listening to similar tracks?
    By Kwahine14 in forum Ask a Question
    Last Post: 12-04-2017, 12:28 AM
  2. Why can't I set my lock screen on my s6 edge?
    Last Post: 12-03-2017, 08:43 PM
  3. Just moved from 950xl. Trouble selecting text for editying.
    By scadaman29325b in forum Samsung Galaxy Note 8
    Last Post: 12-03-2017, 08:34 PM
  4. My voice to text is not working
    Last Post: 12-03-2017, 08:30 PM
  5. Where do I plug the charger into the smartwatch phone
    Last Post: 12-03-2017, 07:38 PM
