1. spottydog10's Avatar
    Hi all, nice to be here.
    My GF's phone is an LG K4 2017.
    If you try and use the mic to create a text message this only works when connected by wifi.
    I presume this is because of Google play. Is there a way of using the speech to text when not connected?
    Her older Galaxy phone would do this.
    Thanks for any help,
    Mike
    12-04-2017 07:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you saying this doesn't work when she's connected to the web via mobile data?
    12-04-2017 10:47 PM
  3. spottydog10's Avatar
    Hi B.Diddy, thanks for the welcome.
    I don't know if she is or isn't to be honest. Her Samsung Galaxy didn't need to be connected to simply write a text message through the mic but the LG K4 doesn't seem to be able to do the same. If you try, the mic appears but keeps saying "Try again"(or something similar) and never lets you speak a text but when connected to wifi works fine.
    Any hints gratefully received.
    12-05-2017 07:00 PM
  4. B. Diddy's Avatar
    Follow these steps for offline speech recognition: How to enable offline Speech To Text in Android. The exact menu location may differ depending on the phone.
    12-05-2017 11:24 PM
  5. spottydog10's Avatar
    Thanks mate, I'll try it at the weekend and report back.
    B. Diddy likes this.
    12-06-2017 08:27 AM
  6. spottydog10's Avatar
    That worked great, thanks!
    12-12-2017 10:50 PM
  1. Disapearing texts
    By RRHMJ23 in forum Moto Z
    Last Post: 12-06-2017, 10:52 PM
  2. Replies: 1
    Last Post: 12-04-2017, 10:34 AM
  3. How to prevent sending blank SMS on Samsung Note 8
    By dalanga7 in forum Samsung Galaxy Note 8
    Last Post: 12-04-2017, 07:50 AM
  4. Replies: 1
    Last Post: 12-04-2017, 07:37 AM
  5. How to prevent sending blank SMS on Samsung Note 8
    By dalanga7 in forum Ask a Question
    Last Post: 12-04-2017, 05:43 AM
