1. wizard-zoso's Avatar
    delete
    12-06-2017 01:22 PM
  2. Rukbat's Avatar
    The tab has 160MB of storage - hardly enough for any apps at all these days (as time goes on, apps get larger - after 7 years [it's that old], maybe you should rethink your desire to use the device). You're not going to find a browser that supports flash and that can run in it. You're not going to find many apps that will install in it, and most that will, will run very slowly. (Connect it to the Google Play Store directly and see what apps show. There probably won't be many.)
    12-06-2017 01:48 PM
  3. VidJunky's Avatar
    I agree with Rukbat, a device with such low specs is not likely to have many apps still available on the play store, and even fewer that can run on such a model from sources out side of the play store. Anyway, if you can get connectivity on the device through WiFi or a tether of some kind, you might try browsing the internet for a cloud based browser. You navigate to them using whatever browser your device has and then do your browsing from their platform. That's how we solved the Flash player issue back in the day. The cloud service runs flash and adobe and any other add-ons and simply displays them on your screen. It was almost a VPN with just a few differences.
    wizard-zoso likes this.
    12-06-2017 02:10 PM
  4. wizard-zoso's Avatar
    delete
    12-06-2017 02:49 PM
  5. wizard-zoso's Avatar
    delete
    12-07-2017 09:46 AM
  6. B. Diddy's Avatar
    Merged threads, since they are about the same subject.
    12-07-2017 12:04 PM
  7. wizard-zoso's Avatar
    Mystery Science Theatre fan I see Cool
    B. Diddy likes this.
    12-07-2017 01:37 PM
  8. B. Diddy's Avatar
    Heck yeah! Gave a decent amount to the Kickstarter that brought it back for the current season.
    12-07-2017 06:05 PM
  9. wizard-zoso's Avatar
    Cool My mom and I love that Show Forever
    12-07-2017 08:05 PM
  1. Replies: 10
    Last Post: 12-08-2017, 09:06 AM
  2. dial request modified to dial with different number On Android 7.1.2 LG V30
    Last Post: 12-06-2017, 03:56 PM
  3. Problems with my Samsung galaxy S7 edge and straight talk
    Last Post: 12-06-2017, 02:00 PM
  4. A little black dot with a cross in the middle how to remove
    Last Post: 12-06-2017, 01:15 PM
  5. When you hit the Reject feature for an incoming call, does it go to Voicemail?
    Last Post: 12-06-2017, 12:30 PM
